I've bought a Leo Vince infill panel. It sort of fits but the two bottom holes have nothing to attach to. I was wondering if anyone has modified one to fit their bike? Cheers Gary
I think the front hole had a bracket that bolted to one of the sump bolts and the rear hole connected to a clamp that was around the link pipe. You could make a bracket like the Racefi one that bolts to the two holes behind the shock then a flat plate to the two holes on the panel. I will try and get a picture of mine in the morning to try and give you an idea.
I just got a Leo Vince infill as well, not fitted yet but it came with 2 brackets and a clamp for round the pipe, looks a bit fiddly but everything has somewhere to attach by the looks of it
I couldn't get the clamp to fit or the longer one of the two brackets. I didn't think about mounting the clamp on a different way so I will try that later. What exhaust do you have fitted?
Thanks I have a Mivv fitted so I know it won't fit straight on, just wondering if I could make it fit
Mine fits, but to be fair I do have a Leo Vince fitted so if it hadn't fitted I would have been somewhat miffed
The Racefit panel has a curved piece of steel attached behind the shock to two holes already there. It then goes to a flat plate that lines up with the holes in the carbon panel. I have tried to show it in the photos but it is hard to get in.
