Motion Induced Blindness
Discussion in 'Lounge' started by Dave-uk, Mar 7, 2012.
  1. Dave-uk
    Dave-uk Active Member
    Some good info fellow riders:D, the link is a good example too:D
    Lack of motion Induced Blindness (pilots and drivers too)
    Lack of motion Induced Blindness was presented as a flying issue, but one can also miss things (pedestrians, motorcycles, other cars) while driving, so, keep your heads and eyes moving. The below link is a great illustration of what was taught about scanning outside the cockpit when military pilots went through training they were told to scan the horizon for a short distance, stop momentarily, and repeat the process.
    This was the most effective technique to locate other aircraft. It was emphasized repeatedly to not fix one's gaze for more than a couple of seconds on any single object. The instructors, some of whom were combat veterans with years of experience, instructed pilots to continually "keep your eyes moving and head on a swivel" because this was the best way to survive, not only in combat, but from peacetime hazards (like a midair collision) as well.
    The most dangerous target is the one that has NO apparent motion. This is the one you will hit without evasive action and also the one you will NOT see as presented below.
    This advice had to be taken on faith until technology produced the display linked below.
    MSF
    An article in the March issue of the UK magazine Bike added a bit to the understanding of why cars pull out in front of motorcycles. Research on how certain insects attack prey was applied to the SMIDSY crash (sorry mate, I didn't see you).
    When attacking, a dragonfly stays directly in the line of sight between its potential dinner and a fixed point in the distance. If dinner moves, the dragonfly alters its path just enough to stay on that line of sight. It doesn't swoop out to "lead" its victim. This tactic has the effect of keeping the dragonfly at the same point in the prey's visual field. Because the prey sees no change in the big picture, it is unaware of the impending attack. This is called motion camouflage.
    Motion is difficult to perceive when it is directly along the line of sight. Because the object is stationary relative to the background, an observer doesn't see a change in the overall image and thus isn't cued to the presence of a moving object. Though the object increases in apparent size as it nears, the change goes unnoticed at first--moving from 1000ft distant to 900ft may not affect the image enough trigger a response. A motorcycle is particularly susceptible to motion camouflage because its cross-section area as seen by an observer is much less than that of a larger vehicle.
    But as the object gets closer, apparent size increases more rapidly. At constant speed, an approaching object takes the same time to move from 200ft to 100ft as it did from 1000ft to 900ft, but the apparent size increase is greater. Eventually the object seems to grow suddenly in size, and the motion camouflage is broken. This is called the looming effect. According to the Bike article, when an observer is startled by the looming effect, he may freeze in his tracks. If the observer is an oncoming left-turner, he may stop in the middle of the intersection, making a bad situation even worse.
    Duncan MacKillop, the riding instructor who related motion camouflage to motorcycling, suggests that diverging from the direct line of sight will break the motion camouflage and get the observer's attention. For example, a driver stopped at a cross-street on your right will be looking left at a slight angle to the path of the road. If you stay to the left of your lane, you will diverge from his line of sight, making yourself more noticeable. But if you're veering right (say, moving from the left to the right lane) you'll be moving along the crossing driver's line of sight, helping to hide your motion against the background.
    MacKillop recommends: "I observed a smooth, gentle, single, zig-zag motion, at any point along the line, created a rapid edge movement against the background and destroyed the motion camouflage. Drivers' eyes snapped towards me and they froze the movement I swept left to right and back again."
    This is something Jo and I will adopt, both when we approch red trafic lights and when we spot someone waiting to pull out of a junction. :D
    #1 Dave-uk, Mar 7, 2012
  2. abv
    abv Active Member
    I've used this tactic for years. When approaching a car waiting at T junction I always make a point of moving sideways within my lane. I haven't had a close one for ages so I believe in it.
  3. Givover
    [​IMG][/IMG]
    Cheers Dave just tried it out and it works.
  4. Benn The Pig
    I to do this but I didn't realise this is why I was doing it it just made sense to me!
  5. Villan
    Villan Active Member
    I didnt do this but will now give it a go. Thanks
  6. kpone
    In his autobiography Chuck Yeager put most of his success as a combat pilot down to his scanning technique. He would focus on the horizon and pull his focus back in zones towards himself. More often than not he would pick up on other aircraft as he flicked from one zone to the next, relying on the superior acuity of his peripheral vision and the changeover in focal distance.
    That and the fact that he's nails.
