Motul C5 chain paste
Discussion in 'Maintenance' started by tuktuk, Feb 7, 2018.
  1. tuktuk
    tuktuk Elite Member
    Anybody use this? I know it sounds stupid but any tips on application or just slap it on, rub it in?
  2. Cambo
    Cambo New Member
    Just apply it all over the chain, no elbow grease required, and use a tooth brush for the bits the applicator wont reach.
    I used it once, but didn't like it because it picks up all the crap, although I can see it lasting a while between lubes, if you're not bothered about how the chain looks.
  3. nigelrb
    Hmph! That counts me out!:D
  4. tuktuk
    tuktuk Elite Member
    Sounds shite lol.
    Only bought it as i was looking over a race bike a few weeks ago and it had the paste on and I thought thats a good idea as im always spraying lube all over the place.
    Cant beat that S-Doc 100 white it seems!
  5. nigelrb
    Haven't heard of that, though just looked on eBay. I bought 'Wurth' on Lozzy's recommendation and found it good so far - less fling than WD 40 Chain Lube.
  6. tuktuk
    tuktuk Elite Member
    Sdoc stuff is really good compared to the small selection ive tried in the past.
  7. raphael
    raphael Elite Member
    Was told by a salesman it’s better on off-road bikes so I didn’t bother
  8. tuktuk
    tuktuk Elite Member
    I was thinking i could use it on the mx bike as normal lube lasts seconds plus the chain has no o rings etc so might help.
  9. Slick
    Slick Elite Member
    C5 is messy as hell, coverage is not too hot either, attracts grit like no other!, becomes a grinding paste in no time.
    Used it for short while then ditched it ,I only have it now to lube pins of the connecting rivet when fitting a chain.
    If you did use it on a non sealed chain it would need to warm/hot to allow it to creep into the the roller/pins
  10. Slick
    Slick Elite Member
  11. nigelrb
    I hadn't seen that test. Very good means of analysis.
    Now, I'm going to mix some blue glitter with my Wurth for added bling effect!:cool::cool:
