motul chain paste
Discussion in 'Maintenance' started by bonjo, Dec 20, 2022.
  1. bonjo
    bonjo Active Member
    has anyone used this and what was the outcome?
    like: ease of application, fling, longetivity and ease of cleaning
  2. Saqib
    Saqib Active Member
    I've not used it. Are you planning on touring etc?
    I use Motul C2 Road, and Castrol Chain Lube Racing. I really like both of them - clear and not too much fling at all. I don't really ride in the mucky conditions though.
  3. bonjo
    bonjo Active Member
    Thanks pal
    I was just looking for the holy grail of chain lubricating
    Good wear and rust protection, no fling, easy to apply and clean afterwards
    Yes I am lazy!
    Since posting the thread, I found an old one discussing this product.
    The outcome was not favourable so I’ve shelved the idea
  4. Saqib
    Saqib Active Member
    Thanks for the update.
    What are you going to use then?
  5. bonjo
    bonjo Active Member
    Been using worth dry lube for years and can’t recommend it enough but it is weak when it comes to corrosion.
    So started mixing it with xcp.
    First coat with xcp after a chain clean followed by a couple of dry rides then 2 coats of wurth.
    The balance seems to work specially keeping the rust away during winter riding.
    Of course spraying is not as clean as putting the paste on with a brush
  6. BlackDevil
    BlackDevil God Like
    You should be able to right-click on the text and choose Translate this page. The text should open in Google Translate, ready for you to read in your preferred language.
    https://www.hks-czech.de/
    Product description
    HKS extremely the Juwel under the lubricants for extremely high-pressure necklaces with long term effect HKS extremely is a dünnflüssiges lubricant that when applying, the integrated capillary effect to the smallest Hohlräume reach, so always a string of optimum lubrication even in the interior, the hochbelasteten chain bolt, installation time. After 3 - 5 minutes Abdunst - Ungszeit builds up a greasy film similar to the form of a plastic coating with long term effect. The Greasy Film is 3-5 times thicker than ordinary lubricating films, so makes it Ruckdämpfend and chain sequence noise are extremely are reduced. HKS extremely produces a durable, thick fully waterproof a greasy film similar to the form of a plastic coating HKS extremely has an extreme suction and reaches up to the hochbelasteten friction spots against HKS extremely Sealed against dirt and water HKS extremely will not Abgeschleudert HKS extremely lowers necklace nachstellung much HKS Super ensures a smooth running, without loss of performance HKS extremely acts very quiet and Ruckdämpfend HKS extremely no chain cleaning for to smudge HKS extremely completely o/x/W Ring compatible with 2500 km chain lubrication intervals 6 attributes that only HKS offers. 1 Sealing effect: prevents dirt and water from entering 2 Langze Itsch Mier Movie: 5X longer lubrication Erinte Rvalle than conventional chain lube oil 3rd for quickly ready for use: After applying the cream in 3-5 minutes ready for use, will not Abgeschleudert 4th 5 x thicker a greasy film layer thickness: Noise Of Ruckdämpfend and Verschleißmindernd 5th the smallest dose: allows economical and targeted consumption No environment pollution 6 optimal care of the chain Innenlebens: securely attaches to the hochbelasteten chain bolt package size: 300 ml spray can
  7. Edy
    Edy Member
    I use Acf 50 corrosion block grease. I clean and lube the chain as normal then put a really, really light coating of grease on the links. It has stopped the little bits of rust appearing. I do ride in the rain, sometimes, and am not a cleaning fanatic, so the grease helps.
  8. Blade runner 1
    Blade runner 1 Elite Member
    I’ve never got on with any of the dedicated chain lubes, I’ve always reverted back to gear oil. Don’t do a massive amount of miles or commute, so it’s not a huge issue. Would be good to know if anything good comes along though.
  9. Lozzy
    I've been using Wurth dry chain lube for years...I hate fling and its one of the few that doesn't do it. I use the bike in winter and do a lot of yearly miles and find if I keep on top of washing and lubing the chain it's been fine. I wipe some acf50 on it too...havnt a clue if it helps or whether I should but my chains last so hey ho
  10. bladey
    bladey Senior Member
    I always clean the chain with paraffin, dry it off then spray on whichever chain lube gets a recommendation from Ride or similar. ACF50 as well if it's not going out for a few weeks. Seems to be ok so far.
