Mounting a GPS
Discussion in 'Mods, Upgrades, Accessories and Products' started by SteveMac, Aug 31, 2013.
  1. SteveMac
    SteveMac New Member
    I tend to do lots of miles on my bikes, on all my previous bikes in recent years I've mounted a Garmin, whilst I await the delivery of my new steed, I've been pondering mounting sites.
    Has anyone fitted a Garmin, can't be the first.
    Cheers
  2. sps170373
  3. Pete H
    Pete H Active Member
  4. SteveMac
    SteveMac New Member
    I'm using the 550 too, would be keen to see a pic. cheers.
  5. sps170373
    Will sort tomorrow for you
  6. sps170373
    This is how I mount my Garmin Zumo 550 I can power it two ways either semi hard wired or using an Optimate power lead
    This is the semi hard wired option
    Both power leads
  7. sinewave
    The 'prettier' solution! ;)
  8. SteveMac
    SteveMac New Member
    Cheers lads, thanks for taking the time to post, really handy.
    Your right Sinewave yours is more elegant, but I'm way too tight to buy a new GPS to replace my trusty old Garmin 550. :)
    I was planning on going for my usual power setup and pinch a feed of the back lights. should be ok, only ever had dramas with BMW and their CANBUS systems.
  9. sps170373
    Mine was low down like yours sinewave but found I was having to look down to far which made me nervous when taking my eyes off the road! And it also fits with a full tank bag.
  10. SteveMac
    SteveMac New Member
    Previously I've always mounted mine on the left hand grip. might try that area again but central could be good too.
  11. sinewave
    Yes, I did need to make a few adjustments with a full Tank bag and despite how this side on Pic looks, I can see the full screen area when in a standard riding position with no craning of the neck required.
    More importantly I can also see the full dash including warning lights! ;)
  12. SteveMac
    SteveMac New Member
    Some interesting Mods Sinwave, obviously using your Blade for more than just a Sunday Blat!
    The luggage bars look handy, who supplies those, Vario? , and the tank bag too?
    Cheers
  13. sps170373
    Likewise that why I positioned mine where it is so you can see all the warning lights and not have to take you eyes off the road to much!
  14. BlackDevil
    BlackDevil God Like
    Garmin Montana 650T
    Garmin Montana 650T
  15. sinewave
    Luggage Rack is by Renntec
    Honda CBR1000RR Fireblade Motorbike Accessories From Renntec
    Tank Bag is by Givi which used the tank lock system which clipe on and off in 5 seconds flat and doesn't touch any paint work.
    GIVI XS307 Tanklock Bag - Givi Top Boxes | Givi Side Cases | Givi Fitting Kits | Monokey Box | Monolock Case
