My rear brake is pants
Discussion in 'General 1000RR Discussion' started by Scott, Sep 16, 2013.
  1. Scott
    Scott Active Member
    Not that I use it a lot but might be nice if I do want to.
    Are yours crap to ?
  2. sinewave
    Most Bikes rear anchors are shyte, if they weren't you might end up crashing! :D
  3. madmac
    madmac Well-Known Member
    I was going to ask the same question - mine is all but useless. Loads of travel and no stopping. Pads look fine. Was going to try bleeding it but mine is a C-ABS model tho so I'm assuming the bleed method will be different?
  4. arthurbikemad
    You can upgrade them :)
    Then it works tooooo well!
    #4 arthurbikemad, Sep 16, 2013
  5. gRRandeelion
    gRRandeelion Active Member
    What's a rear brake?
  6. arthurbikemad
    It's the one that settles the bike in fast corner entry or puts the front back on the road without backing off with full throttle corner exit :D
  7. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    I've found on every bike I've ridden that the back brake is pretty much like trying to stop the bike using two blocks of cheese, barring a CG125 that I did my CBT on.
  8. arthurbikemad
    It's the age old do you don't you....use the rear brake that is....
    Me I love it and hate bikes without it, but then I was brought up on MX bikes etc and that's all I use... McPint loves it (thumb brake to steady the bike and keep front down is my guess) so lets argue that's why he's fastest....lol
    Anyway brakes slow you down, don't use any of them is the answer...corner speed baby that's what you need....lol
  9. Yorkshire Tyke
    I only ever use the back brake when going down a steep hairpinish hill, like stelvio. Or when controlling the bike <10mph other than that I don't touch it, although the few times I've had to but the anchors on I've used it with the front
  10. scooby
    scooby Elite Member
    only use mine when grass tracking.....
    it's worth noting,when you do bleed it,helps if you lift the caliper up above the m/c,as the rear line tends to be quite looped up so holds the air in there.
  11. just_me _and _me _bike
    jeeze that is sexy!!!! :)
  12. just_me _and _me _bike
    only use mine for very slow riding stuff to keep bike balanced or when filtering through heavy traffic, again to keep bike upright and balanced, otherwise use engine braking to slow her down :)
  13. Scott
    Scott Active Member
    Il try bleeding it up there thanks mate. Just fancied it for the front wheel over the mountain at cadwell really
  14. Kentblade
    Kentblade God Like
    Mines an ABS, and the back brake is strong, and you want some front, you just push the pedal harder.
    Regularly brake from 30 or so just on the rear only, just to puzzle oher commuters and brighten up the daily commute
  15. BladeWitch
    BladeWitch New Member
    you only use rear brakes for low speed when parking or to "sometimes" stabilise in corners otherwise its front brakes, front brakes and yeah, more front brakes.
    #15 BladeWitch, Sep 17, 2013
  16. Jamiestrada
    You wont have time to think about using the rear brake over the mountain !! just balance it on the throttle and hold it up the straight ;)
    This clip always makes me smile .... Black Flag lol
  17. navvy10
    navvy10 Well-Known Member
    My rear brake was awful and wouldn't give much of a bite no matter how hard pressed. Fitted braided lines front and rear and the rear brake is about 1000% better! I can seriously stop the bike with it now :)
  18. BikersDiscountStore
  19. BladeWitch
  20. *AL*
    *AL* Active Member
    I only use the rear brake at low speeds like in town or heavy traffic, I also use it as a handbrake whilst stopped and hill starts.
