Hey guys I've just bought a 2011RR-B and it's got a full akra system on it, Question is I can't seen to find a PC on it, not under either seat, which to me is strange as you don't tend to spend £1500 on a system and then not have a PC to set it up to it Or can the standard ecu be mapped ? Hope for some info cheers Ronnie
Yes it is possible for the ecu to be remapped, not sure how you would find out though, how is the bike running with the akro ?
Seems to be running fine, no rumble when letting off the throttle to fuelling is good, Only other place it could be is under the tank cowl but that's a funny place to put it :/
If it wasn't advertised as having a PCV on it then I'd assume there isn't one there If you lift the tank up you'll see the extra plugs connected to the injectors which manage the fuelling. These plugs:
