Neutral gear indicator light inop.
Discussion in 'General 1000RR Discussion' started by Troys7012, Apr 14, 2014.
  1. Troys7012
    Troys7012 Active Member
    2011 repsol gear neutral indicator lamp not working anyone had any issues with this and is it the switch above the gearshift that controls this lamp?
  2. Troys7012
    :rolleyes:Hello anyone? Problem still persists,I tried earthing out the wire that goes onto the neutral switch ,this should light the lamp on the dash ,nothing happened,stripped out the instrument,s tried a continuity check with a multi meter ,getting a resistance reading on the wire that,s the same colour,but think it maybe through another unit as bike does not want to start if neutral switch is not connected,also checked the main multi plug just down from instruments,very clean no sign of corrosion ,as I would expect as the bike only gets used in dry mainly.now thinking it,s either the led in the instruments or broken wire
