Can someone check that the pillion seat on attached looks like it has the correct underside attachment for installing on my 2014 Blade? Just need a cheap fix to use while carrying my kriega tail pack. Thanks https://www.ebay.ie/itm/Rear-Passen...147743?hash=item1cda099e5f:g:mdIAAOSwcDBdiiC2
RM I have a 2009 (not sure if the fittings are different on your later bike) but i slip the 2 kriega straps under the seat and fasten onto the tail pack and for extra security pass 3rd strap under the grab handle and clip onto the front of the tail pack. Stable enough on the Autobahn at 168
It's a little bit hard to be 100% sure as the white colour on my screen is difficult to see but I'd say 99% that the hook at the back is the same as my OEM one although mine is black.
