new battery?
Discussion in 'Maintenance' started by raphael, Sep 11, 2016.
  1. raphael
    raphael Elite Member
    my bike's been on the stands for a week on the optimate,when i went to start it today it didnt want too and needed a lot of throttle.
    it made a wining type sound when pressing the starter, does this sound like the battery is on the way out?
    on the motobatt website it only show's a cb1000, would tht fit my 2012 1000rr?
    cheers
  2. sps170373
    Is yours abs or non? If non it's a ytz-7s if abs you need a ytz-10s
  3. raphael
    Cheers Steve,
    Looking into whats available for the bike and if anything better about as have heated grips and usb lead on there now,what with the cold weather on the way soon too may need that little bit more starting. Motobatt seams ok and pretty cheap too
  4. sps170373
    I have a motobatt as a spare if you need something till you get one
  5. sps170373
  6. raphael
    Thanks steve, will hopefully be here in the tomorrow?
  7. bonjo
    bonjo Active Member
    check the Ah and CCA of any alternative battey to yuasa.
    I believe the USB adaptor is a constant poer drain! so be careful with the pea size CBR battery.
    best in my opinion is to take the battery to a reputable shop to do a battery health check.
    If it has sulfated, then some of the cells have reduced / no storage capacity so although the volts will read ok, the charge capacity of the battery is reduced.
    if your charger has maintenance/ desulfation mode, give it try.
    but in the end it may not be the battery :(
  8. Wayne_R
    Wayne_R Active Member
    Just to ask in this thread - I've just fitted a Motobatt to my bike, and note that the positive connector is fouling the seat when trying to locate it back on. The connector is sitting slightly higher due to the brass fitting position. Is this normal or have I cocked it up??
  9. sps170373
    No they are a tight fit and do sit slightly proud! Just make sure you have pushed it all the way down as it shouldn't foul the seat
    #9 sps170373, Nov 27, 2016
  10. graemewalker
    graemewalker Elite Member
    Started mine up first time in 4 months battery optimists on for winter
  11. Lozzy
    ;) :D
  12. Dave dunlop
    Dave dunlop Elite Member
    4 months!!!!!!
    That's outrageous Graeme.... you need to get off that Monkey bike of yours:D
  13. graemewalker
  14. graemewalker
