New caliper bolts EVERY time I take remove the caliper?
Discussion in 'Mods, Upgrades, Accessories and Products' started by bash1k, May 9, 2015.
  1. bash1k
    bash1k Active Member
    guys - does everyone replace their caliper bolts every time they need to remove their calipers? I am going through them (nice Pro Bolt and Brembo ones too, not OEM stuff) like they're going out of fashion as I'm having to play around with forks and calipers at the moment and I know you're 'supposed' to change them, but I'm on my third set of bolts in under 50 miles so I'm keen to know if I'm being overly cautious.
  2. Cbrjay
    Cbrjay Well-Known Member
    I've never changed mine mate
  3. Scott
    Scott Active Member
    Ur nuts
  4. Dave
    Dave Member
    No i wouldn't change them everytime, just torque them back up as required. Possibly change them if they have been in and out a number of times.
  5. bash1k
    Ok glad to hear others re-use them! Honda say they need replacing whenever they are removed, and seeing as its the brakes I'm definitely happy to stick to their recommendations... but if folks are re-using theirs with no issues maybe I should too :confused:
  6. ColinBR
    I don't know of anyone that changes theirs and seriously doubt even when getting serviced that Honda would do it.
  7. Blade048
    Blade048 Active Member
    No I have never changed the caliper bolts. For Honda to suggest you need new bolts every time you remove the calipers is ridiculous.
  8. bash1k
    Decision made, I'll be re-using caliper bolts from now on.
  9. thezipsteruk
    thezipsteruk Elite Member
    If you are using the original Honda bolts they do indeed suggest that you replace them.
    I was told by the mechanic at doble that the OE stuff is a stretch bolt and over time they will distort (he had an amusing story to back this up, but I fell asleep).
    Having said all this he said the easy solution was to replace them with aftermarket stainless bolts or similar.
    This is what I was told and I replaced them on the repsol but haven't needed to yet on my red beastie.
    Hope this helps
  10. bash1k
    Perfect so I wasn't the only one who had that information. Well I've got aftermarket ones so I'm all set :)
  11. Slick
    Slick Elite Member
    Had mine off several times(a year) and they still haven't fallen off!
  12. Mike07
    Mike07 Active Member
    I don't replace but I think its worth cleaning them and putting new thread lock on.
    Mike.
  13. Mr OCD
    Mr OCD Well-Known Member
    Clean the threads and a dab of threadlock ... Stretch bolts my ass ... They are only torqued to 33lbft!
  14. sinewave
    Re-use!
    Change mine once a year and that's it!
    They get undone and redone loads in the interim.
  15. ShinySideUp
    ShinySideUp Elite Member
    Pretty much the only bolts garages change while doing work is normally head bolts due to the torques involved while bolting the head on after carrying out head work! Unless they are damaged and not advisable to be reused or they are specifically told to change by you and in both cases you cover the extra costs.
    Ford vehicles was the most visible I have seen where stretch bolts are in action, again mainly head bolts.
    But when dealing with the pretty small torque values of those found in the likes of caliber or fork pinch bolts and the likes if you keep to using torque wrench set to correct value the oem bolts will last and last but if someone tries to do a superman and racks the bolts up way beyond then of course the bolts will be showing signs of damage and should be replaced.
  16. lambchops
    lambchops Elite Member
    I read that went to price the bolts and thought "don't be silly" reusing
  17. Gilesy
    Gilesy Elite Member
    I just bought Ti bolts ages ago.. take them on / off as much as you want :)
  18. Jimbo Vills
    Mine have been off prob 50 times...I'm still alive and the bike stops just fine...
    Didn't even know you was meant to change them.... :eek:
  19. exuptoy
    exuptoy Elite Member
    Aren't the callipers also fitted onto spigot rings to locate them? So basically there's no side loading due to the spigots.
  20. exuptoy
    If you've been replacing the old Ti ones, can I have them! :D
    • Funny Funny x 3
