next mods suggestions
Discussion in 'Mods, Upgrades, Accessories and Products' started by skinso, Jun 24, 2011.
  1. skinso
    skinso Active Member
    i due to get my back back today with the pcv, hm quickshifter and race airfilter fitted and im already thinking of my next mods, what would you guys suggest? ive already got a yoshi r77, gillies vcr and rcv levers
  2. dan.1moore1
    BST Carbon Wheels...............In improving lap times , aparently the most affective mod you can get for your bike and look the nuts swell... expensive thou
    OZ wheels are nice swell and a bit cheaper
  3. dan.1moore1
    Also how about a secondary Fuel module to control the other 4 injectors
  4. sync24
    sync24 Active Member
    I read on the power commander website that the secondary fuel modules are only worth fitting on highly tuned race engines and are not required on a mildly tuned bike......
    Power Commander V Secondary Fuel Module Most of today’s high performance, four cylinder Sport Bikes have two injectors per cylinder. The Power Commander V connects to 4 of those 8 injectors. In virtually all cases the PCV’s +250% / -100% fuel adjustability allows more than enough adjustment for all but the most radically altered engines. However, we recognize that there are people building heavily modified engines (extreme big bore, turbo, etc) that may require the adjustment of all 8 injectors.
  5. dan.1moore1
    Cool.. saves me some money then ha ha..
    Wavey discs are a cool upgrade swell. Makes the front wheel look awesome. I put armstrong discs on my 600 and they stood out a mile
  6. skinso
    ill pass on the wheels, im 245lbs so saving a little weight on wheels would do nothing, they are nice tho
  7. dan.1moore1
    it would actually ..Its not the weight saving its that the light wheels don't give as much gyro affect resistance when turning no matter how heavy you are the bike would be a lot faster throu bends. Probably only a contributing factor for track use though, I Doubt a rode rider would care if he gets some where 3 seconds faster lol
  8. skinso
    just checked them wheels out, they're sweet would need them repsol orange tho and my wife would cut my balls off if i bought them
  9. dan.1moore1
    Lol same here. Way over budget
  10. fisher
    fisher Active Member
    Rear Thumb brake, nice and trick, doesnt cost a fortune, and very handy for practising wheelies
  11. flatstickHRC
    flatstickHRC Active Member
    Brembo 18x19 MC and braided hoses and OE clutch lever. It's the future.
    Or how's about a suspension revalvei just bought a HM shifter but suspension will be my next (and probably final) upgrade.
  12. skinso
    i didnt pick the bike up tonight as the rain is bouncing of the ground here but went up for a look anyway and to give my mate a few £ for the work, the shifter is fitted tho he had to cut a bit of the shift rod asit was too long.
    as for the pcv (well happy with this) my mate got a map from the hm plant team and tweaked it on the dyno to suit my bike. alli need now is dry roads
  13. skinso
    i also have the orange hel brake lines
  14. Nutty Tart
    Nutty Tart Well-Known Member
    We can dream tho' .... :yes4:
  15. fisher
    GPR steering damper
  16. dan.1moore1
    It will never be final ..... Your hooked ha ha
  17. flatstickHRC
    Don't tell he wife. It's getting beyond a joke. I was goin to keep this more or less standard
  18. JM1
    JM1 Active Member
    A Scotoiler :)
  19. ray
    ray Well-Known Member
    Some panniers :)
  20. skinso
    Maybe gold chain and sprockets
