No-cut Fairing Crash Knobs Recommendations
Discussion in 'Mods, Upgrades, Accessories and Products' started by Jae, Nov 4, 2018.
  1. Jae
    Jae Active Member
    Hi all,
    Does anyone know where I can source no-cut fairing crash knobs? Hoping to find the type that sits in the open middle section fairing for a 08 blade. Cheers
  2. nigelrb
    We have these and a variety of others in UK. Shipping might be expensive for you though.
    A Google search might throw up some local distributors for you.:)
  3. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
    My recommendation: Forget about the "No Cut" crash knobs.
    Make a hole in the fairing and place proper crash knobs in the proper location, or don't use them at all.
  4. Jae
    Jae Active Member
    I travel back and forth but will be in the UK early next year hopefully. Link?
  5. Fwsock
    Fwsock Active Member
    Only problem with no cuts is the risk of the mounting bracket getting bent when u drop it and you can’t remove the mounting bolt to change the bracket. It’s a risk you don’t get with the cut type. Buuuuut.... depends how often you intend to drop your bike m8. There are also c9lour coded and bike branded no cuts available on AliExpress.com which probs ship to oz. hope this helps.
  6. Jae
    Jae Active Member
    Thanks for the link nigelrb, much appreciated.
    Fwsock, I'll have a browse on Aliexpress and see if I can find anything to my liking.
