No fuel pump noise but turns over.
Discussion in 'Maintenance' started by Leo-v, Aug 11, 2014.
  1. Leo-v
    Leo-v Active Member
    Hi guys,
    I own a 2005 cbr1000rr, I believe I'm having a fuel pump issue.
    When I turn the ignition on, I'm used to hearing the fuel pump prime and observing the rev needle set itself.
    However when I turn the ignition on I no longer here the fuel pump. The starter turns fine and sounds strong.
    The kill switch is not on. The fuse seems fine. Any other suggestions?
  2. Muffking
    Immobiliser?
    Side stand down and in gear?
  3. PeterT
    PeterT Active Member
    Crank position sensor.
  4. Leo-v
    Leo-v Active Member
    Thanks for your suggestions guys. I'll get to it and take it from there.
  5. Dave
    Dave Member
    Also check out the tilt switch.
  6. lambchops
    lambchops Elite Member
    Do you have any error flashing lights on the dash?
    You can tell if it's the pump put a meter over the two of the wires to the fuel pump, can't remember which colours sorry you should see the priming voltage when you turn it on. I bet you have a sensor failed but should flash up the error code really.. Could be fuel pump relay. Same as headlight one so swap them over to check. Tilt sensor can't remember what else.. Have you got the manual it will tell you?
