Yo guys Booked at Oulton on 31st and I've just realised the dB limit is 102, though it was 105 like cadwell. Bit worried because my trackbike doesn't have a baffle and I'm pretty sure its louder than my blade with the Yoshi which was 101. Where can I get a baffle made?? Cheers
Wire wool packed in the end would do the job to pass noise testing but you would have to remove for track but they could have you on the ride by noise tester , I am sure Scooby or someone else will have a cheaper alternative than having to buy a baffle .
be carefull with oulton though,they are very strict. but,a crushed coke can with a bit of wire wool or exhaust wadding will do the trick,problem is,if they see a baffle of sorts,your sticker will be marked as such,then if you get pulled off track and dont have it in then your in trouble.might see if we can put it at the bottom of the end can that way they wont see it.
