Noisy engine - video in msg
Discussion in 'Maintenance' started by David13, Dec 17, 2015.
  1. David13
    David13 New Member
    Hello everyone
    My bike is just coming out from maintenance and they made me notice a noise in the engine.
    They can t tell me what's wrong without dismantling the engine.
    I made this video hopping someone may have an idea
    Engine has 22 000 KM
    Vidéo :
    (Video is in french, I am saying the noise is only when the engine is cold, has it get warm, the noise disappears )
  2. ShinySideUp
    ShinySideUp Elite Member
    Imh videos never really give a true representation of the sound that human ears hear when up next to the source anyway.
    That sort of noise could be caused by quite a few things but try and narrow the cause down a little further before handing it over to a garage.
    Is the noise actually coming from inside the engine or outside?
    Is there any loose items on the outside in that area along the lines of a rusted out exhaust clamp that rattles when cold but when the heat builds up it reduces the gap and there for the noise?
    You can use a screw driver as a crude stethoscope to better locate the area the noise is coming from.
  3. dansp1
    dansp1 Active Member
    sounds like an exhaust blow, can be from the emissions gubbins too
  4. David13
    David13 New Member
    Thanks all for your help...
    I have to think of all of it
    Thanks !
  5. Si.
    loose front sprocket?
  6. red5
    red5 Well-Known Member
    Unless you have a Harley running close by I'd suspect the cam chain tensioner.
  7. Alblade
    Alblade God Like
    I can tell you for sure that its not got a washer in the cylinder head rattling round inside it as I know what that sounds like..
  8. dansp1
    What did you find was the problem?
  9. Geoff Paxton
    Geoff Paxton Member
    Too much oil in it. Check level and drain off.
