O.Z Piega Forged wheels in black cbr1000rr 08-14
Discussion in 'Parts, Accessories & Clothing' started by 08blade, May 4, 2015.
  1. 08blade
    08blade New Member
    Hi there
    My light weight O.Z Piega Forged wheels in black are up for sale
    off my 08 fireblade will fit all 08-14 non abs models
    Excellant condition straight and true
    Alongside suspension these are the best mod ive done massive improvement on cornering acceleration and braking noticed it straight away. Also look amazing.
    These retail at £1800 new
    After £1000
    Pm me for contact details, based in london/hertfordshire
    Thanks
  2. hoggyjay
    hoggyjay Active Member
    Hi,
    Are they 17"? I am looking for an after market set that I can use Brembo M4 calipers with. The Dymags I have at the moment don't have a big enough offset causing the brake disk to rub the caliper. Do you have any idea if theses wheel would be the same?
  3. fez.57
    fez.57 Well-Known Member
    Which model of dymags are causing that ?
  4. 08blade
    08blade New Member
    These are 17"
    Im pretty sure they will do as i beleive m4 calipers can be used with stock wheels and these where a straight direct fit, i litteraly just bolted the stock discs onto the O.Z's and fitted wheels
    Hope this helps will try to research it a little more
  5. hoggyjay
    Cheers,
    I have 16.5" magnesium drys and aluminium wets. They came with the bike and I've not really had a good look at the serial numbers. The Brembo's are the correct model for the blade. Its not easy to describe but the gap that the disk runs in, is narrower that the standard caliper causing the rub. A local engineer had a go at adapting them by removing some of the body of the caliper but leaving enough to retain the brake disk. Unfortunately it did not work. my only option was/is to use a spacer between the hub and disk. I have had mixed advice about this. Some say its huge no no, other say it can be done. I might give Dymag a call.
  6. kev.b
    kev.b Well-Known Member
    Will look great on your Blade SPS ! :D
  7. RepsolSam
    RepsolSam Well-Known Member
    Are these different or better then PVM wheels? As they are £1k new?
  8. 08blade
    08blade New Member
    Not too sure why the pvm are so cheap but the O.Z retail at way more than what im asking and are an amzing bit of kit youl never lose money on them at that price
  9. 08blade
    08blade New Member
    Now on ebay
    231554132028
    #9 08blade, May 7, 2015
  10. fez.57
    Where can you find pvm wheels brand new for 1k ?
  11. 08blade
    08blade New Member
    Ive never seen any wheels worth getting for 1000 new.
  12. foenix
    foenix Active Member
    and they are .... where i have bought 2 sets since 3 years.
    i have mentioned the website on another post. :)
  13. sinewave
  14. 08blade
    08blade New Member
  15. RepsolRuss
    RepsolRuss Active Member
    PM sent
  16. sps170373
    Pm sent
  17. 08blade
    08blade New Member
    Now sold
