o2 eliminator
Discussion in 'Mods, Upgrades, Accessories and Products' started by trueuk, Mar 8, 2015.
  1. trueuk
    trueuk Active Member
    hi could anyone tell me exactly where the connector is for the o2 eliminator on the abs 2011 model. I thought it was going to be around the side stand but I think its under the tank somewhere. any pics would be appreciated thanks
  2. Slick
    Slick Elite Member
    need to lift the tank, it's on the front left. sorry havent got a picture
  3. bash1k
    bash1k Active Member
    What Slick said... and it's fixed to the inside of the frame. No photo, sorry
  4. sps170373
    You can actually reach it with out lifting the tank I did, trace the wire back from the O2 bung unplug lambda sensor then plug o2 eliminator in.
  5. sps170373
  6. trueuk
    Thanks guys
  7. benya
    benya New Member
    Same question. I have a 2017. Installed a set of Akrapovic headers. The 02 lambda sensor wire is not long enough to reach the bung in the exhaust! I tried re-routing it to no avail.
    I traced the wire up to the lhs frame spar. How do I unplug it? No way to see in there!
    If I get a custom dyno tune, do I need an eliminator plug? Can anyone point me to the correct eliminator?
    Last question, what size plug do I need for the Akrapovic 2017 header?
