So I've fitted my Yoshi and PCV but where is the connector for the O2 connector ? I've tried tracing the cable back but it disappears under the left hand fairings and I don't really want to strip it down more than I absolutely have to. Anyone got any pics that could help me out ? At the moment the sensor is just cable tied out of the way and it seems to run ok. Am I risking any problems runnning it with out the eliminator ? Sounds awsome Cheers
Thanks for the help, I've found the connector now but my ABS is a bit different to the pic shown there is a big plastic cover on the left that needs to be removed and then there is a big ABS valve unit right in front of where the connect is. Has any one done this on a ABS ? I spent a hour trying to do it this morning my wrists are scratched to fuck but I just can't get the connector apart. I'm wondering if I can get to it from above some how.
Did it to mine mate. I didn't go in from the side. I got it from the top after removing the tank when fitting the powercommander. The connector sits on the inside of the frame 'left side' next to where you plug in the powercommander. There is 2 connectors attached to the inside of the frame. 1 is the connector you are looking for. Can't remember which though.
Cheers Mate. Just found this thread too which says I can get to it from above. http://1000rr.co.uk/mods-upgrades-accessories-products/801.htm It's amazing how complex bikes are now. Even comparing with my 2006 GSXR track bike the Blade is very hard to work on. Every spare cm2 of space is used. Regardless of the fuelling I have to say the Yoshi sounds awesome
