having just bought the blade and reading upon loads of mods, just wondering with a racefit fitted and i plan to fit an air filter and get a ecu flash or pc5, is it worth fitting the o2 sensor delete plug? ive read they run lean with a can on as standard too
If you fit a PCV you have no option, you have to remove the O2 sensor. Otherwise they would be fighting against eachother.
Cheers pal, it’s definitely coming off then but can I do the bypass plug while it’s standard before I get the power commander?
Yes nothing stopping you. I don't think you'll notice any difference though. The O2 sensor just manages the fuelling at idle and low rpms I think. With it disconnected I imagine it will revert to a baseline mixture that is slightly rich. I could be wrong though.
