O2 sensor?
Discussion in 'Maintenance' started by phantomx0_1, Jul 5, 2012.
  1. phantomx0_1
    phantomx0_1 Active Member
    Ok so I have ordered a Jardine RT5 exhaust. I doesn't use the O2 sensor (lambda sensor). I have bought an O2 eliminator. Does that plug in under the seat? Also what do I do with the sensor at the exhaust? Zip tie it u somewhere?
    Thanks fitted exhaust before but never one with a O2 sensor.
    :D
  2. Tom68
    Tom68 Active Member
    When i did something simlar to my 600rr i just swapped the origanal O2 sensor for the elminator, Due to the Micron exhaust not having a hole in it for the O2 sensor. I just followed the wire up, Disconected it and plugged the eliminator in.
  3. phantomx0_1
    Thanks
    Anyone shed some light for the RR8?
  4. chelseaboy
    chelseaboy Active Member
    No its on the left hand side behind the frame, where the screw holds fairing to the frame,just behind fireblade badge, look behind and you will see it
  5. phantomx0_1
    Cheers I will trace the wire back
