OEM exhaust refit
Discussion in 'Maintenance' started by RRoss, May 5, 2016.
  1. RRoss
    RRoss Active Member
    How easy is it to refit standard exhaust? There's a cable attached to it if I remember right,it's been in box in loft since new. May be trading bike in and was gonna return everything to original if I do.
  2. bonjo
    bonjo Active Member
    it should be straight forward specially if you have the maintenance manual. The cable is for the exhaust valve motor which is located under the seat.
    Akro web site gives a good installation doc with pictures
