Hi guys. Could anyone out there help me atall. I'm looking at buying a new set of ohlins forks, has anyone had experience with either the fgrt's. I quite like the look of the newer ones but not sure they will fit the 2008 blade. And does anyone know if both the newer and older ohlins will fit the brembo gp4rx billet calipers ? Any help would be much appreciated. Cheers Danny.
Fgrt 813 are the forks for 08-11 but will fit 12 plus bikes and will fit all calipers as the they were made without the spacer dimension Fgrt 204 which I have are for 12 on bike but will fit 08 plus, caliper wise you cannot fit Brembo M4 as they require the spacer to be removed on the std fork, ohlins made the fork with the spacer dimension So you can either machine the fork mounts or calipers or the HPK calipers will fit as I have them on my bike unsure on GP Basically if they need a spacer on std fork they might if they don't they won't (spacer is 5mm on std) Hope this helps
