Hi This might be a daft question but should you be able to twist/rotate the shock on its axis when mounted to the bike. (I.e if you hold the reservoir you can rotate it) Mine seems to have an excessive amount of movement and was wondering if the bushes have had it. The bike is new to me so I didn't fit it. Not mastered uploading a video yet , so I've put a few pics up. Cheers Mike
I'll check mine tomorrow and let you know if it does the same as I can't remember off the top of my head, even though I had it serviced and fitted it myself..
Like everyone else says: If it moves its ok... Its due to the ohlins having a rose joint for mounting on either end. https://en.wikipedia.org/wiki/Rod_end_bearing
The Ohlins rose joints are easy to replace, they do wear with age given there is no seals in them, I replace mine every 8 thousand miles, cost about £16
