Oil leak
Discussion in 'Maintenance' started by bazzashadow, Sep 16, 2023.
  1. bazzashadow
    bazzashadow Elite Member
    A4566B91-D30A-44DF-B864-674DF1A317AF.jpeg IMG_4297.jpeg IMG_4298.jpeg IMG_4298.jpeg IMG_4297.jpeg As you all know I have been having a bit of bother with the oil leak.
    I have started to strip it down and it’s wet over one side of the air intake housing
    #1 bazzashadow, Sep 16, 2023
  2. Broadie
    Broadie Active Member
    Is it coming up the breather into the air box? Is the air filter all manky
  3. Boothman
    Boothman Elite Member
    That does sound like some kind of back pressure issue
  4. bazzashadow
    Doesn’t look like it
    Looks dry round the breathers
  5. bazzashadow
    It looks like it’s came out of the air intake:confused:
    I wondered if the vacuum pipe was feeding it back
    But surely that would be sucking not blowing
  6. bazzashadow
    Cleaned it all
    Put it back together and took it out
    Just to cheer me up a bit
    • Friendly Friendly x 2
  7. Broadie
    Silly question but is it engine oil? It's not a badly fitted failed scott oiler.
  8. bazzashadow
    No mate it is engine oil
    Haven’t got a Scott oiler
  9. Selmer50mark
    Selmer50mark God Like
    It's obviously settling at the side stand side of the air box , could it be slightly over filled with oil Bazz .
    Asking for a friend ;)
  10. bonjo
    bonjo Active Member
    Unless the oil is on the outside of the airbox seeping in, then my money is on over pressurerised crankcase caused by either too much oil or blow by gases
  11. Broadie
    Take the cam cover off make sure the breather is clear and has the baffle plate is there. I'd also think about using some BG44K and BG109
  12. bazzashadow
    What the f is bg44k
  13. Broadie
    BG44K is a fuel additive that will clean up the fuel system and combustion chamber. I've used this for years it's fricking amazing, loads easier than taking the carbs off that old bike every time you feel like riding it.
    BG109 is an oil flush. Had an er6 that was really ringey, burnt oil, stank . Honestly didn't think it could work being a flush how much could it do. But thought I'd give it a go off the back of their fuel additives working so well. Nothing to loose apart from £15.
    Some times it's pays off having a punt on someone based on your previous experience.
  14. Boothman
  15. bazzashadow
    Sorry mate
    I have been out on it
    Might try this afternoon
  16. Barstewardsquad
    Sure the dealer will say it is fine and to be expected
    #16 Barstewardsquad, Oct 8, 2023
    • Funny Funny x 5
  17. bazzashadow
    The Harley able has got a leak as well:(:(:(:(
    Air leak:mad::mad::mad:
  18. Lozzy
    Good.....
    Hopefully Mr O'Reilly will pick it up on his scrap wagon if you leave it at the end of the street lol
    • Funny Funny x 2
