Oil
Discussion in 'Maintenance' started by steve thomas, Mar 18, 2017.
  1. steve thomas
    steve thomas New Member
    I've got white scum on oil filler but not in oil , is it condensation
  2. dansp1
    dansp1 Active Member
  3. steve thomas
    Thanks mate
  4. dansp1
    no charge, avoid short hops where it doesn't really get up to temperature, if you don't use it over winter don't run it up for 5 mins from time to time
    oil needs to get hot enough to burn off the condensation
  5. edderby
    edderby Active Member
    Totally agree - if starting up in the winter for a few minutes then run it until the fan comes on so that there will be no condensation in the engine or the exhaust. You'll cause no oil emulsification from doing that.
  6. bonjo
    bonjo Active Member
    it's also known as mayonnaise!
