Opening filler cap while tank is disconnected will....
Discussion in 'Maintenance' started by Coda, Sep 7, 2022.
  1. Coda
    Coda Active Member
    I've got the tank off the blade (SC59), which is full to the brim. I didn't have anything at the time to syphon the fuel into when I needed to take it off. At least, with the quick disconnect detached, its not pissing out fuel. Is this because:
    A) the fuel pump needs to create a vacuum for fuel to flow, or
    B) tank filler cap is closed, and therefore sealed so it won't leak
    I've got a jerry can coming, so I want to transfer most of the fuel out of the tank before I refit it. And obvs I don't want fuel going everywhere when I open the filler.
    Ta.
  2. CharlieR85
    CharlieR85 Elite Member
    It's sealed on the QR coupling. You can open the filler cap.
