I’m chasing up a fitting for my optimate 4. I have the permanent female fitting on my battery (white, one square one semi rounded) and looking to put a usb power point to charge my drift and go pro but need the adaptor for the SAE fitting. Does anyone know the part number or had/got one? It’s not going to be a permanent USB fitting just plug in as and when needed.
Sportsbikeshop have a heap of different leads. Might be quickest to try them. See here: https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/103719
If your any good with a soldering iron then you could make your own? https://www.ebay.co.uk/itm/Optimate...007923&hash=item1a7c8be74a:g:EAoAAOSw3ydV1KWR
that's a good link hitch. You can also buy the TM/ Tamya connectors individually: GZ98 or GZ99 those connector are crimped so you should be ok. You can of course solder them if you prefer
