optimate charger
Discussion in 'Maintenance' started by Gshock, Oct 28, 2014.
  1. Gshock
    Gshock Active Member
    I have a new blade and I have a socket on the left of the seat is this for diagnosis or to plug in my optimate as it does fit???? all new to me...:confused:
  2. Womblewizard
    Womblewizard Active Member
    Does sound like a optimate plug can you not follow cable back and see if it goes to battery?
  3. sps170373
    A picture paints a thousands word! But like Womblewizard said probably an optimate charging lead
  4. Kentblade
    Kentblade God Like
    If its just 2 pins and meters around 12.7 VDC or lower depebding on batt charge, then its connected to your battery.
  5. Barstewardsquad
    If it has two wires and is white it may be a tamiya connector. If it is black then it could be an SAE connector. Google them and you should get pics to compare against yours.
    If it is round then it may be a headset connector. Could be anything from a single hole to 5/6 inside it for intercoms cables.
  6. Gshock
    Looks like a Tamiya but weatherproofed in rubber with a cap, my optimate charger fits it just making sure it is what I think it is? will try to get a pic
  7. Gshock
  8. Gshock
  9. MrB
    MrB God Like
    optimate
  10. Gshock
    Thank you
  11. sinewave
    Yep, Optimate.
    Nice Chicken Strips BTW! ;)
  12. Greco
    Greco Active Member
    The carbon exhaust looks great!
  13. Gshock
    not my bike or chicken strip by the way, just a pic to show the socket, cheers anyway
  14. morpheus20170
    morpheus20170 Active Member
    Optimate mate
