Original exhaust info '15 blade
Discussion in 'Mods, Upgrades, Accessories and Products' started by SteveDustyDe, Jul 22, 2018.
  1. SteveDustyDe
    SteveDustyDe Active Member
    Has anyone got info or photos of the inside of the original exhaust? I'm wondering what the second flapper inside is and does.
  2. SteveDustyDe
  3. nigelrb
    Isn't there only one flapper operated by the servo that opens at about 3,500 rpm?
  4. SteveDustyDe
    I've seen on the forum that older bikes have a second "pressure" flap and there's definitely a spring that could open a flap inside my exhaust as per photo. Would be good to see if anyone has cut open the original.
  5. SteveDustyDe
    Don't suppose anyone has any experience of opening up an original 2015 exhaust? I think there are 3 chambers and I'm looking at cutting through one and then reinstating the servo flapper. Plan is to have a quiet bike leaving home and noisy when I open her up! Hopefully the servo flapper doesn't close up over a certain speed or gear?!? Anyone know for sure if it's just closed at idle and less than 5k revs?
  6. SteveDustyDe
    Going to search online for a cheap damaged original to experiment with now..
  7. roboticus
    roboticus Active Member
    im sure iv seen an x ray and what I can remember was inside there's a welded camber inside, don't think u can do anything past the flapper mod
  8. SteveDustyDe
    If love to see that photo of the x-ray. Maybe even more so than a photo of Rachael Riley in her birthday suit!
  9. roboticus
    off memory think it looked like a bladder inside, guessing the pipes go into that
