Overfilled reserve tank.
Discussion in 'Maintenance' started by bradt, May 30, 2016.
  1. bradt
    bradt Elite Member
    Have overfilled reserve tank with coolant, should I siphon some off or is it ok to leave about the upper level ?
  2. RRoss
    RRoss Active Member
    About the upper level or way over it? Ideally somewhere between the 2 marks,siphon some out to be safe.
  3. bradt
    bradt Elite Member
    With the bike on paddock stand I've gone above the upper level by about 20 mm
  4. RRoss
    RRoss Active Member
    Should be measured when bikes level. Think 2cm over when on stand would be more if it was level. Not sure exactly what would happen if you left it but I guess the chance of hot fluid squirting out is best avoided.
  5. sps170373
    Would take a bit out, last thing you want is coolant coming out of the overflow pipe mid turn and going over your tyre
