Genuine Honda owner's manual 07/08 are these all the same i have a 06 theres one on ebay and i need one for my blade if it the same any one know
here is the one for the 04-07 CBR1000RR_2004-2005.pdf oh and I also have the hrc 06 one if you fancy a read. tells you how to do the pair valve mod too. CBR1000RR_HRC.PDF
I uploaded that so there should be a download tab at the top right that will download it to your desktop.then just burn it. the mod is on page 2-44 shows you what all is removed.instead of HRC cones like the instruction says you just have to find something that will plug the holes air tight.this mod just stops the bike doing the popping with a free flow exhaust and also gives more accurate air/fuel readings on the dyno.no power gains from it.
