Oxford-Valve-90-Tyre-Schrader-Connector
Discussion in 'Mods, Upgrades, Accessories and Products' started by samuk, May 3, 2012.
  1. samuk
    samuk Well-Known Member
  2. arthurbikemad
    Ok to inflate, or get a Bridgeport 90deg valve fitted next tyre change, search ebay for them you need 11.3mm
  3. samuk
    looks like they are meant to be a permanent thing, as the valve cap can screw onto this..
  4. arthurbikemad
    Yes they are but heavy objects such as this and bling valve caps cause stress on the rubber valve leading to cracks and loss of air I would not leave one on..
  5. ahmedf
    ahmedf Active Member
    wow, never knew this, but makes sense! learn something new everyday.
    not to derail, do you know the size for 09 600rr bridgeport valve size by any chance?
    Thanks
  6. arthurbikemad
    I think it's the same mate, it pays to keep and eye on rubber valve fittings as they perish and crack the tyre fitters should check them or better still replace them when new tyres are fitted.. As for those big bling caps the gyroscopics pulls the heavy valve cap back and in the end they crack and deflate the tyre, be warned it could be at speed for those with golf ball size valve caps.. :)
  7. bluekontakt2004
    bluekontakt2004 Active Member
    All honda's well all CBR's anyway use 11.3mm bridport valves. I have some on my blade.
  8. arthurbikemad
    OZ Racing do them too :) See BTR for them...
