padlock jammed
Discussion in 'General 1000RR Discussion' started by rebel, Aug 16, 2017.
  1. rebel
    rebel Active Member
    the padlock that I use to chain my bike to the ground has jammed cannot open it I need to get it sorted tomorrow I got two choices £15 bolt croppers from machine mart or a £30 angle grinder from skrewfix disc included my question is will 18 inch bolt croppers go through a 12mm hardened chain
  2. sps170373
    You tried oiling the lock? Sometimes soaking in oil and giving a tap with a hammer sorts out a stuck lock
  3. rebel
    rebel Active Member
    tried all that had it soaking for hours and tapping with a hammer no good
  4. Gaffa22
    Gaffa22 Well-Known Member
    I bet some thieving little scum bags could open it in a few seconds
  5. Kentblade
    Kentblade God Like
    Can of spray freeze on a link then hit it with a sledgehammer, unless its a top end chain, that normally works.
  6. CharlieR85
    CharlieR85 Elite Member
    Unless it's the cheapest and nastiest chain you won't get it like this. You will make yourself very frustrated and have a sledgehammer wielding around a few feet from your pride and joy.
    Angle grinder.....because it's a much more useful tool than a set of bolt croppers are to have in the garage.
    #6 CharlieR85, Aug 17, 2017
  7. sulaco
    sulaco Active Member
    Some good youtube vids on getting locks opened, might take a while sorting through em, but something may be of use.
  8. rebel
    rebel Active Member
    thats what I was thinking bought the angle grinder job done
  9. tuktuk
    tuktuk Elite Member
    How long did it take to steal your own bike?
    • Funny Funny x 2
  10. sps170373
    At least he didn't have to turn up on a moped to grind the lock off the bike
  11. travellingkiwi
    travellingkiwi Active Member
    Been practicing again KB?
