Painting wheels
Discussion in 'Mods, Upgrades, Accessories and Products' started by bazzashadow, Feb 19, 2022.
  1. bazzashadow
    bazzashadow Elite Member
    Hi all
    How much should you expect to pay to have your wheels painted?
  2. raphael
    raphael Elite Member
    Powder coated around my area is 50-70 per wheel if not damaged and straight forward.
    Lot more durable than spraying apparently
  3. Trackit
    Trackit Active Member
    Just remember if you are power coating the wheels you will need to remove the bearings, this adds to the cost.
  4. bazzashadow
    My son has just had his wheels paint by someone who was recommended from a friend But they are by far not the best:(:(:mad::mad::mad::(
    He got charged( well I did;) ) £110
    If that’s cheap he will put up with them but if that’s on the money he should take them back​
  5. Lock
    Lock Active Member
    Painted mine myself, took quite a bit of prep time and probably about £60 of primer, paint and lacquer. Happy with the finish, shame my tyre iron slipped as I was refitting tyre though, oh well!!
  6. warren smart
    warren smart Active Member
    Always take them to a reputable company, I’ve seen to many cheap jobs where the disc surfaces have been sprayed and bolt holes full of paint, to do it properly pull the bearings and fit new as they’re relatively inexpensive, somewhere like wheelhouse tyres do a great job.
  7. Jez
    Jez Senior Member
    one of the downsides with powder coating is they they can soften your wheels by over cooking, they do low temp powder coat but not many use it
