pair valve removal guide
Discussion in 'Mods, Upgrades, Accessories and Products' started by phantom, Aug 2, 2013.
  1. phantom
    phantom Active Member
    Thought I would make this little guide if anyone else was
    Going to do the same mod
    • Like Like x 6
  2. ColinBR
    Nicely done.
    Can you post up a link to where you bought the blanking plates from?
  3. phantom
  4. ColinBR
    Thanks for that.
    I'll get a set ordered.
  5. phantom
    start to finish without a fitting guide took me less than an hour.
  6. ColinBR
    I'm sure I will be fine mate.
    Have you felt any difference since doing the pair mod?
  7. phantom
    it doesn't pop anymore but I done it for when I get round to fitting an autotune and getting custom maps done.
    it is also meant to lower the running temp but I wasnt out that long to notice.power wise its only
    meant to add 1lb-ft of torque so no big gains to be had there.
  8. dogman
    dogman Member
    So if you just wanted to try out this mod without doing the full removal you could just block off the Pair intake on the bottom of the airbox??
  9. phantom
    yup exactly, block the intake in the airbox.
    I just like to de clutter around the engine lol.
  10. Scott
    Scott Active Member
    Why block the intake in the air box ?
  11. phantom
    the pair valve intake if you want to block the pair valve?
  12. Scott
    Scott Active Member
    Yea iv stuck bolts in the end of my pipes an didn't know about the pipe in the air box. I Spose untill I realised when I put it back on
  13. phantom
    you plug the airbox as well as the hole is after the airfilter and this is to stop
    cr@p getting in the hole and straight into your engine intakes.
