Need advice on how to fix my fireblade 2008, crashed on track and need to fix bike for track racing. My problem is bike wont start after the crash I suspect there is a inertia switch or ECU reset procedure, does any one know where I can find this info to do it my self, I am an engineer and can fix it if I have info for how to do it. Also I have stripped fairings and lights, engine turns over but won't start.
Now then ... there is a tilt sensor (small black box) in the event of dropping the bike . I wonder if you have damaged that . You see them on eBay selling for little money . Oh and by the way .. :welcome:
Yep tilt sensor would be my first guess I have had a pinched wire from where the handlebars closed to far. I couldn't start it due to the broken wire. Check/replace the tilt switch and trace your way through the wiring loom and check for broken/pinched wires They're are no Ecu reset that's is required.
welcome - sorry to hear about your tumble, hopefully it's just plastic and metalwork damage and flesh and bones are all Ok !!
