Pazzo Levers?
Discussion in 'Mods, Upgrades, Accessories and Products' started by hondastan, Mar 23, 2014.
  1. hondastan
    hondastan New Member
    Hi everyone,
    I have short Pazzo levers on my 06 Blade, will they fit on a 2008 Blade??:D
    Thank you in advance.
  2. JM1
    JM1 Active Member
    Brake will be ok. But 06 clutch is hyd and 08 is cable
  3. derchef
    derchef Well-Known Member
    you can just order a different pazzoracing adapter for 2008> 1000 rr , than fit your lever
  4. hondastan
    That's great thank you for your time!:)
  5. mikegml
    mikegml Active Member
    I have 'short' Pazzo levers on my 07RR I picked up at the weekend. The clutch is ok but the brake lever is definitely too short for the job IMHO. I spent quite a while yesterday moving the lever towards the hand grip to give a good three finger grip on the lever, previously I could only really get two fingers onto the lever.
    I had to undo the starter/kill switch and rotate it forward which allowed the lever to move rightwards about 15-20mm. Still not totally happy and may get a long brake lever to replace the short one.
  6. Blackness
    Blackness Active Member
    Short levers are only meant for 2 fingers I thought !
  7. mikegml
    Maybe, and they can be operated with two fingers but theres quite a difference in the lever positions due to the starter/kill switch on the brake side. Had to position my throttle hand further to the left than felt natural. Clutch lever as I said is ok. I use two fingers with normal levers anyway. I've not got small hands either.
    P.S. Is it me or are the clutch and the throttle on the RR7 both a bit sharp?
    #7 mikegml, Mar 27, 2014
