Pazzo levers
Discussion in 'Mods, Upgrades, Accessories and Products' started by reid7606, Apr 26, 2012.
  1. reid7606
    reid7606 Active Member
    Got me some Pazzo levers but I have found that the their is a lot of 'slack' in the clutch lever, will I have to fit a internal bush to stop this ?
    Cheers
  2. MrB
    MrB God Like
    1cm of slack is recommend if that helps.
  3. reid7606
    Happy days but it seems proper loose. Both up/down left and right movement.
  4. Jamiestrada
    They are like that the Pazzo levers I had on the R1 which were the same :) as long as your happy with them in use all will be ok
  5. phantomx0_1
    phantomx0_1 Active Member
    You have fitted the old metal tube Like washer (sorry can't remember the proper name!) that you take from the old lever to fit tothe pazzos? Haven't you? Otherwise there will be far to much slack! Common mistake.
    #5 phantomx0_1, Apr 27, 2012
  6. Tom68
    Tom68 Active Member
    +1 with phantom. it's a silver bush about 5mm in length.
  7. phantomx0_1
    BUSH that's it!!!
