pcv help
Discussion in 'Mods, Upgrades, Accessories and Products' started by fez.57, May 7, 2013.
  1. fez.57
    fez.57 Well-Known Member
    Can somebody please talk me through the following process
    Currently on my pcv i have a custom map loaded onto it but i have another custom map that was sent to me by si in an email. how do i upload this new map onto the pcv but also keeping the old map at the same time incase i want to swap back again. is it all done using the software disc that loads the pcv programme onto the computer and then connect the computer to the pcv ?
  2. Jamiestrada
    Open software and once it connects click get map save the file to your comp with a name you choose, once thats saved click open map find Si's map and click it so it opens in the software, then click send map and it should load to the PCV
    Hope this helps and make sure you get map and save first :)
  3. levin
    levin Active Member
    Don't forget to save ur own custom map first or it will be gone
  4. fez.57
    Cheers guys all sorted now and both maps are saved :)
  5. Jamiestrada
    Always a pleasure to help you Fez :)
