selling the following dynojet products for a 08-16 blade. Power Commander 5 16-034 £175 Comes with O2 sensor eliminator instructions software and USB cable. Mapped to suit. Fits 08-16 blades PCV ignition module £125 Retails at £350 with this you need a power commander 5 already fitted. It plugs into the PCV and you can have a pit lane Limited as well as launch control. You can also use a dynojet quickshifter with this. Quickshifter Expansion module and push quickshifter £185 Again you need a power commander 5 to use this setup. It comes with all you need to fit and run. Give me a ring if you are interested. I will send pictures etc. 07921849075.
I am interested in the PCV ignition module , is this still for sale ? its lat at night so here is my number to txt 07883009020 thanks
