PCV map for Akra road version (with cat/flap)
Discussion in 'Mods, Upgrades, Accessories and Products' started by ccr32, Mar 28, 2015.
  1. ccr32
    ccr32 Active Member
    Hi all,
    So I have taken the plunge and ordered myself an Akra exhaust, just the road version with the cat and exhaust flapper as I'd like the bike to run/idle as close to standard as possible, and I haven't had much luck in this regard with the other exhausts I have tried.
    I know from speaking to MrOCD that the Akra has been designed to be plug and play and so a PCV shouldn't be needed, however I have a PCV now anyway so was wondering what the best/correct map would be to use on it?
    Had a look on the Dynojet site and there is not much there for a 2012-13 European bike.
    Any thoughts or personal experience?
    Thanks.
  2. Cbrjay
    Cbrjay Well-Known Member
    What year bike you on?
    I've got 14 plate with acky can, runs well but I've taken the cable off cos to quite under 4000rpm
  3. Cbrjay
  4. ccr32
    ccr32 Active Member
    2013 for me, so slightly different version I am guessing as Honda changed the exhaust/cat position in 2014 I believe.
  5. Cbrjay
    Think my cats in the headers
  6. ccr32
    ccr32 Active Member
    Correct.
  7. Cbrjay
    Is yours not?
    Could never got to the bottom of what is different, was told different size of pipe as well
  8. ccr32
    ccr32 Active Member
    Nope. AFAIK, the cat in the 2008-13 bikes is in the standard can, which is understandable when you take the thing off and feel the weight of it!
    2014+ they moved it to the headers I believe. As a result, the diameter of the exit of the headers to where you'd connect a link pipe to for a can is different.
  9. Mr OCD
    Mr OCD Well-Known Member
    Still fucking about with exhausts! :D
  10. ccr32
    ccr32 Active Member
    Haha! I can't help myself :p
  11. Bryan01
    Bryan01 Active Member
    K
    Know that feeling ! On my 4th :) and not finished yet!!
