PCV map information needed.
Discussion in 'Mods, Upgrades, Accessories and Products' started by bluekontakt2004, Feb 29, 2012.
  1. bluekontakt2004
    bluekontakt2004 Active Member
    Right I have just fitted a PCV on my bike. I accidentally put on the wrong map.
    I found that out today because my fule light came on 40 miles early.
    I have now refulled and put the standard map on for a bike with no mods.
    My bike is an 05 blade with a yoshi gp force can, no other mods.
    I am going to get a custom map done. this is just an interim thing.
    Here is the question. I downloaded the maps from power commander. saw on the website that the gp force map is clearly labled under the 2005 maps.
    Go to put it in but it comes up on the PC software that its for an 06-07 bike. Can i use this map? or will i be left short of fule again. I only did 80 miles and the fule light came on lol. wasnt hammering it either.
    Basically is dose the 06-07 use the same fule ratio as the 04-05?
  2. arthurbikemad
    Yes mate you can use the map should not drink fuel so my advice would be get to dyno asap.
  3. bluekontakt2004
    Will be getting a dyno setup done as soon as i have the funds. Will leave the no mods map on for a few days and see what happens, If all is good then I will try the gp force map.
    Dyno will get done in march most likely.
  4. arthurbikemad
    Dont forget if you have a problem you can load a zero map and it will run with no correction at all.
  5. bluekontakt2004
    cool, cheers mate.
  6. bluekontakt2004
    Im just glad i have a laptop as well as a pc. How would i explain trying to get the bike up the stairs? lol.
  7. arthurbikemad
    Lol long usb cable like me mate...lol
  8. JM1
    JM1 Active Member
    Yeah the PC6 better be wireless :)
