1. Benn The Pig
    I note I can get a PCV for my GSXR 1000 for £200 from USA, but here their £270 ish.
    Is their a difference from the US model to ours???
  2. CastrolCraig
    CastrolCraig Active Member
    Arthurs your man for this, but if i remember right its only a case of running a uk map anyway.
  3. arthurbikemad
    Cc right, unit is the same, there ecu has a timing retard and thats where the irc comes in for usa customers.
    Posted on my HTC Sensation with Tapatalk
  4. djfleming22
    djfleming22 Active Member
    The biggest difference we get screwed and the Americans don't....... plus they have bigger f***** guns
  5. kpone
    Left hand drive, definitely.
  6. Bats
    Bats Active Member
    Remember no dyno centre in the uk will touch this ie if it goes wrong etc! and i no for one FWD developments ie Dynojet uk wont even map it for you!
  7. CastrolCraig
    Is that a recent delvelopment Bats? not doubting your info here but i had an 06 ZX6R PC3 firmware update & check done by FW JR in August and that was a US Model,
    It was also then Dyno'd by BSD with no issues???
  8. Bats
    Bats Active Member
    I must be wrong then all i no at the time of me buying my first one for the 07 on ebay my mate said make sure its a uk model or we wont touch em!
  9. CastrolCraig
    Not trying to argue BTW bats, i know they sometimes wont repair them, and some dyno guys may be aprhensive, but you would get it done, at the end of the day they claim hours from dynojet US anyway.
    When did you get your 07 done?
  10. dan.1moore1
    Your not totally wrong mate
    What it is , is that Dynojet UK won't honour the warranty on a US model .. If it goes wrong you will have to return it to the US
  11. dan.1moore1
    Soprry didn't see Craig's comment above ..
  12. Benn The Pig
    cheers gents, coupled with the possible problems and the fact I could be hit for £70 import tax ill save myself the hassle n get a uk one!!!
  13. Bats
    Bats Active Member
    Mine was done 2 and half years ago! And ok Dan
  14. Benn The Pig
    Right I got one how hard are they to fit and use???
  15. Bats
    Bats Active Member
    Easy and easy! Tank off seat off tail unit off! Fit in tail unit Rought wire past battery connect a earth to battery route wire about engine crank case till you meet the four primary injectors the lower ones unplug plug pcv wire in then honda loom to pcv wires! Then tidy and rebuild plug in laptop install pcv suite off web site dload map for your set up plug into bike and install map! Start bike and enjoy haha ;)
  16. Benn The Pig
    What do you do with the hanging wires just leave them or do they piggy back???
  17. Bats
    Bats Active Member
    Piggy back ;)
  18. Bats
    Bats Active Member
    I and one is for throttle switch ;)
  19. CastrolCraig
    Yup, and the TPS sensor is usually the one thts hardest to get to, right at the end of the injector/inlet rail and squeezed between that & frame.
  20. Benn The Pig
    Ahhh fantastic lol
