Petrol - can i put it into a Gallon plastic container ?
Discussion in 'Maintenance' started by Remal, Dec 30, 2013.
  1. Remal
    I have about a Gallon of unleaded I have sat in my old Fuel tank form my kit car. it has a little crap in it. 10 YO tank. but was hoping to put the fuiel into a plastic container and then use it to clean my chain. Heard many do this.
    but will plastic be effected by the fuel?
    or is it best to get a small gallon petrol container?
    cheers
  2. Barstewardsquad
    Not an expert but I'm believe the answer is that it depends upon the type of plastic as petrol will disolve some plastics.
  3. Remal
  4. megawatt
    megawatt Well-Known Member
    Probably be OK mate, I have some in a 2 litre milk bottle:eek:
  5. t0m541
    t0m541 Senior Member
    It should be fine
  6. Mike07
    Mike07 Active Member
    I have some in a plastic milk bottle as well ... no problems but I keep it outside just in case.
    Mike.
  7. IcarusGreen
    IcarusGreen Elite Member
    It will be fine mate b I wouldn't try to use it in an engine if it's been sat around that long, to be honest it's probably not best for using on a chain as it could damage the o/x rings.
  8. Barstewardsquad
    I store petrol in these for the lawn mowers. The petrol in them is normally is good for a year if you don't open them too often.
  9. ShinySideUp
    ShinySideUp Elite Member
    Matt, don't use petrol for chain cleaning purposes! It will dry out the rubber seals, use paraffin, WD40, dedicated chain cleaners but NOT petrol!
  10. bonjo
    bonjo Active Member
    you are probably thinking of diesel which is the one to use for cleaning chains. This is the one to use anyway. I personally wouldn't use petrol and I don't think it is recommended either as it is too solvent in addition to being a fire hazard!
    Plastic container is only for temporary storage but since youdo not intend to put use the petrol in an engine, then however bad and off it has gone, it doesn't matter.
  11. Remal
    Ahh ok will just get ride of it then. just thought I might have been able to use it some way
  12. Muffking
    You could save it for your lawnmower, cleaning paint brushes, or as weedkiller though.
  13. Mike07
    Probably be okay in a Harley.
  14. Remal
    Would kill my leccy lawnmower but good idea with brush cleaner. been using thinners for that but once it's run out use fuel.
