pins and needles
Discussion in 'General 1000RR Discussion' started by nrabey, Jan 20, 2014.
  1. nrabey
    nrabey Active Member
    hi does anyone else suffer from pins and needles in your hands when riding at low speeds even for short distances worst head effected is my right hand or is this just me? any reply's or remedies welcome
  2. Andy
    Andy Active Member
    Sometimes on long runs, when I've been pushing on, but not short runs
    Maybe try and relax your grip on the bars a little more
  3. sinewave
    It's the throttle return spring causing this as your right hand is under constant muscle stress holding it open, hence why U don't tend to get it on ya left hand.
    The sooner Bikes get Cruise control the better!
  4. Pete H
    Pete H Active Member
    Have you got aftermarket bar ends fitted? I find that the lighter ones don't reduce vibe as much.
  5. A Squids Life
    A Squids Life New Member
    How tight are your gloves? Pins and needles are usually caused by compression of nerves.
  6. Freedom of choice
    Only when riding? At my age I get it when I wake up in the morning.
    As Pete H said, I fitted replaced the OE bar ends with the heaver R&G ones on my Blade and it noticeably reduced the vibes.
  7. Skippy79
    Skippy79 Active Member
    as a suids life said, check your gloves. I had gloves that were a bit too tight and caused pins and needles all the time, problem was that if I went up a size the fingers were way to long. I ended up binning the gloves and buying another brand of gloves
  8. Kentblade
    Kentblade God Like
    As you state riding at low speeds, do you cover the brake lever with your fingers ?
    This can cause the whole hand to be tense, the muscles and tendons, and this normally runs through the arms to the shoulders, everything becomes locked and tense, the whole weight of your upper body ends up pushing between your thumb and index finger onto the grip, and as a result gives you the symptoms you describe. Its exactly the same issue that afflicts a lot of track newbies.
    I know its a personal thing, riding/filtering in heavy traffic daily, I do not cover the lever, as I feel that not only are you more relaxed, but there is less tendency to grab at or ride on the brake lever, or worse a big handful in panic.
    I follow so many bikes in traffic that end up lasering my eyes where the guy is constantly dabbing the lever, but do not really have any impact on braking.
    #8 Kentblade, Jan 21, 2014
  9. Remal
    As posted maybe the gloves but also found again as posted it may be your not relaxing your arms/hands enough. I only had this when gripping to hard and found once I relaxed it was much better
  10. SIDEWAYS
    SIDEWAYS Senior Member
    If you cover your lever like I do, turn the levers down a touch.This made a world of difference to me,I only get it now when on long runs.
  11. nrabey
    my gloves are large but quiet tight across the plams
  12. nrabey
    i got stand bar ends perhaps as you say i need heavier one to try
  13. nrabey
    hi skippy thats problem i have if i go lager the fingers are to long and feel like they gonna catch the levers
  14. Fletch
    Fletch Active Member
    I get it in my right hand all the time ....
    Dont let go of the bar but rotate your wrist so the pressure is off the bit below your thumb ...works for me ....
  15. JimGreen
    JimGreen Active Member
    I had no problems at all with my ZX6R, but when I bought the blade I suddenly started getting pins and needles. I've always ridden covering my brake lever when riding on anything other than a clear road. I found the same comment as "Sideways" posted on another forum and gave it a go, adjusting the lever down. BINGO..... No more pins and needles.
    #15 JimGreen, Jan 21, 2014
  16. gazzer1000
    gazzer1000 New Member
    Yep i posted similar, vibes at 4 to 5000 revs, over winter fitted foam over grips, yet to try but feels like they might work,(2010 blade)
