Pipe compatibility
Discussion in 'Mods, Upgrades, Accessories and Products' started by Noste500, May 1, 2016.
  1. Noste500
    Noste500 Active Member
    if I fit a slip on designed for a 14-16 bike to a 2013 bike , and sleeve the joint down to fit the smaller headers ( larger diam headers on later model )
    What other mods would have to be done ?
    Would it work ?
    Any other fitment issues known ?
    Back pressure issues ??
    Cheers is advance for any info
  2. Punisher5964
    Punisher5964 Active Member
    It shouldn't case you any issues other than the mounting points i wouldn't of thought.
    In order to joint it down from the cat you will need to add in an amount of metal to go from one size to the other, this will push the can back and it wont align with the rear set to mount properly. This is all my opinion.
  3. sps170373
    You just need to find out that the headers end at the same length! That will be your stubbling block, a sleeve is all you'd need then
  4. Cbrjay
    Cbrjay Well-Known Member
  5. sps170373
  6. Noste500
  7. sps170373
    Try a racefit black edition but get the growler end cap so you can fit baffle if needs be
  8. Noste500
    Nice but not the look I was after .
    Cheers
