Plasti dip
Discussion in 'Mods, Upgrades, Accessories and Products' started by rebel, Nov 14, 2015.
  1. rebel
    rebel Active Member
    Any one used it I'm thinking of doing my frame black but I'm more interested with the removal if I cock it up or don't like it is it as easy to remove as people say
  2. Muffking
    The paint itself is dead easy to remove, but overspray is not, so spray wisely and cover everything else up. I'm not convinced it would look good on a frame though and it has a mat finish when dry.
  3. Glb
    Glb Active Member
    Agreed, overspray is a bitch to remove. Even just a single coat is a pain.
  4. SteB
    SteB Member
    You can get a gloss overspray for plastidip. The biggest job is the prep, you have to make sure everything is super clean and dry, otherwise it will peel
  5. exuptoy
    exuptoy Elite Member
    ....and put on plenty of thin coats to build it up. If you leave it on thin you will struggle to get it off.
