Plastic Welding?
Discussion in 'General 1000RR Discussion' started by RepsolSam, Jul 19, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
    Anyone here used or got plastic welding?
    Need to get my panel sorted..
  2. RepsolSam
  3. kev.b
    kev.b Well-Known Member
    Super glue it together then use a soldering iron to weld/ melt all the splits together . push the hot soldering iron tip into the split an work your way along the splits to weld/ melt it together . This works great done it many times. Remove the decals/ stickers first with a hair dryer or heat gun first .
  4. Carlo
    Carlo Active Member
    you can also get some more plastic like a cable tie or something to use like you would be tig welding. if you need to fill in any gaps in the crack
  5. BlackDevil
    BlackDevil God Like
    I got a small crack as well and Honda replaced it under warranty.
  6. LisaRR5
    LisaRR5 New Member
    Hey, did you fix this in the end? I have been looking into plastic welding (for a MUCH smaller job) and searched here for tips.
  7. dansp1
    dansp1 Active Member
  8. LisaRR5
    LisaRR5 New Member
    Thanks I'll check it out :)
  9. gixxerjim
    gixxerjim Active Member
    Drill a small hole at tge end of the crack (s) before you use the soldering iron to melt back together. It stops it travelling further in the future.
    Sent from my GT-I8190N using Tapatalk
  10. LisaRR5
    LisaRR5 New Member
    Good tip! Do you have to use a soldering iron with the q bond stuff?
  11. gixxerjim
    No its a glue
    Ive not used it to repair a fairing.
    I've done soldering iron welding many a time though
  12. LisaRR5
    LisaRR5 New Member
    OK, I have a few repairs to make, some scuffs to the corner of the tail fairings which need filling and sanding and then splits around the mirror mounts so I can try out both options. Thanks for your help!
