Poor Mans Rearsets
Discussion in 'Mods, Upgrades, Accessories and Products' started by Swiss T, Jul 17, 2013.
  1. Swiss T
    Swiss T Active Member
    Still trying to get comfy (locked in) on this bike; the HRC tank shape helped a lot but the standard footrests are just too far forward.
    Rearsets maybe the answer but I would end up paying around £400 for a quality set & even then the adjustment is limited on the brake lever side due to the cabs.
    Jackup plates may work; had them in the past on other bikes but they are not made for this model Blade.
    I came across these recently; a guy I know had fitted them to lower his footpegs.
    I decided to buy them & fitted them today; they are made by Gilles Tooling & cost £85.
    Mine are currently set around 23mm back & 16mm up which feels much better.
    I was worried about reaching the levers but it makes no difference; must be like having smaller feet.
    Pics
    #1 Swiss T, Jul 17, 2013
  2. martinowen
    Pics didn't work mate, you need to copy the image code
  3. raphael
    raphael Elite Member
    Think they look ok fella cant go wrong for that money
  4. phantom
    phantom Active Member
    I was looking at these too but I worried about the reach to the brake and shifter
    in the furthest back position.
  5. dogman
    dogman Member
  6. Swiss T
    The ones I have were supplied with a spacer with 30mm or 40mm offset, but the actual offset differs further depending how you orientate the footpegs; Gilles also supply a 20mm spacer.
    I set mine in the 30mm position & last night went out with tools to make adjustments if neccessary; I had the same concerns as you.
    The brake lever was fine so I left it; couldnt tell the difference.
    The gear lever felt a bit far away & high; I was having to move my foot up a long way to change gear. I lowered the lever approx 8mm (guessed it) & it felt just right; after riding for a few minutes all seemed perfectly normal & the postion set me over the tank better as hoped.
    I tend to ride with my feet on tip toes almost so am used to moving my feet forward to find the levers - my size 8's have no problem with the increased span.
    I will be lowering them a liitle next time out to see how it feels; this will set them a little further back but I want to try it; will probably need to raise the gear lever to compensate.
    #6 Swiss T, Jul 19, 2013
  7. sinewave
    #7 sinewave, Jul 20, 2013
